The clip, mask tool issue of Reality Model and LumenRT exporting problem:
APP: Microstation CE Update 7 or OpenRoads Designer Update 2
Please watch the following video:
https://youtu.be/VO0-t_ADnH0
My workflow:
1, first attaching a .3sm reality model
2, referencing a dgn file
3, using a shape (Construction class) to clip or mask the reality model to show the .DGN up
Problem:
1, When the workflow done, the reality model is invisible after zooming in or out!
2, even if do not zoom in or out, and only export to LumenRT (Update 3), I find that the referenced. DGN model will be clipped by the shape as well. Obviously it is illogical, what is wrong?
but sometimes , the exporting is weird! There is nothing , like what the video showed that the exporting result is black and blank.
Question:
1. How to clip the reality model properly?
2. How to export the reality model(.3sm) to lumenRT properly?
Looking forward to your reply!
Zhengpeng, your ELS Client
Hi, Could you Bentley technical support personnel tell me how to do? thanks
I would recommend posting your issue on the Visualization forum:
https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070#pi25949=1
Hi Zhengpeng,
The issues you are mentioning should be fixed in the next release of MicroStation (Update 8) and LumenRT (Update 4).
HTH,
Mathieu
Thanks for your reply!
Could you please me how to avoid this bug to complete my model? like what the video above showed.
Because the project could not wait us!
As Derval Canny suggested, you should be posting these type of questions to the appropriate group.
Visualisation Forum
