Hi all,
Has the Stencil Tool been removed form Microstation CONNECT? I am using Update 7 and can't seem to find it.
Mark
If struggling to locate tools the following may be of help in the future https://communities.bentley.com/products/microstation/w/microstation__wiki/27894/how-to-easily-find-any-tool-in-microstation-connect-edition
Thanks Carl, is there a way to search all workflows? Eg. If I'm in the drawing Workflow and want to search for a mesh tool.
Mark Shamoun said:is there a way to search all workflows? Eg. If I'm in the drawing Workflow and want to search for a mesh tool.
Yes, Search Ribbon is the answer. If in Drawing Workflow start typing and the command from other workflow will appear in the search query.
Take note that if in 2D model, 3D commands will note appear.
José
Thanks, stlll getting used to the ribbon...
