I am attempting to import Wincore data through Utilities>Macro>Microstation BASIC. After running the wincore.bas file and then selecting to open the .clg file, I receive an error message "Unable to load whose dialog is 1". Any advise on this?
Thank you!
Arthur Vidales said:Has anyone had the issue where you load the macro
Your question is too vague to answer. What macro are you loading? How is it connected to this thread?
Arthur Vidales said:Is there any way to import in OpenRoads?
It looks like you may not be using MicroStation. Please provide more information.
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
I am using a .ba file to bring in my bore log files (clg wincore). I am using the Microsoft Basic tool. I am trying to do the same thing Amber did.
I am using Powergeopak SS10.
Arthur Vidales said: I am using the Microsoft Basic tool
MicroStation BASIC has been obsolete for many years. When Bentley Systems launched MicroStation V8 in 2001 it included both MicroStation BASIC and the much better MicroStation VBA version 6.5. At that time MicroStation BASIC was deprecated.
When MicroStation CONNECT was launched in 2015, BASIC was not included. MicroStation VBA moved to 64-bit version 7.1.
Arthur Vidales said:I am using Powergeopak SS10
Power Geopak V8i SS10 is based on MicroStation V8i.
Arthur Vidales said:I am using a .ba file to bring in my bore log files
A .ba file is a compiled BASIC file. It may include BASIC dialog resources as well as the code. What message do you see when you attempt to start that BASIC file?
.ba
Where did you obtain that .ba file? Did you download wincore.bas or wincore.ba?
wincore.bas
wincore.ba
What is the Microsoft Basic tool? Is that a typo for MicroStation BASIC or something else?
