Hi all,I'm a bit new to using microstation and was wondering if there was a tool to export coordinates every e.g. 1 metre along a line element.The normal "Export Coordinates" tool will export the coordinates of the line at the start and end points.Is there an automatic method to export coordinates at certain increments along a line element?Thanks for the help in advance!
Jacky
MicroStation does not have a specific tool to perform this whole operation but you could use the tool CONSTRUCT ARRAY with the method ALONG PATH to place points at a distance along your element. You can then used the Export Coordinates tool to extract these points to a file.
https://communities.bentley.com/products/microstation/f/microstation-forum/36855/place-multiple-points-or-cells-along-element-specific-distance/81895#81895
Thanks Andrew!This works fine
