Hi all,I'm a bit new to using microstation and was wondering if there was a tool to export coordinates every e.g. 1 metre along a line element.The normal "Export Coordinates" tool will export the coordinates of the line at the start and end points.Is there an automatic method to export coordinates at certain increments along a line element?Thanks for the help in advance!
Jacky
You might also want to try Facet Curve. This command strokes lines and curves using different parameters. One method let you specify fixed length of each new segment.
Krister
Owner consultant at Surell Consulting AB
