I recently purchased the SpaceNavigator to see how it would help improve my workflow. So far the device has been great in Google Earth and Adobe Reader, however it's not as flawless in Microstation V8i.
I downloaded and installed the latest drivers from the 3DConnexion website for Windows Vista x64. I also have the latest version of Microstation V8i installed.
The problem is just when rolling using the device. Roll seems to be hit or miss when trying to roll the drawing I am looking at. If I roll the device counter-clockwise it seems to work somewhat better than rolling clockwise. Also, when I try rolling first, before mixing in any other axis movement, it doesn't seem to respond at all most of the time. However, if I am performing another action, such as tilt, then I try to roll, it will seem to respond more often than not.
I hope this makes sense. Is anyone else having this problem? All other operations with the device work fine in Microstation V8i. It's only the roll function that I am having problems with.
I didn't find the right solution from the internet.References:
https://www.3dconnexion.com/forum/viewtopic.php?t=2790
motion graphics
Hi
The things you report are seen among other users.
Don't get hopes to high, but read these forums, they will help you get started.
https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/marc_thomass_blog/posts/spacemouse-update-for-v10-drivers
https://communities.bentley.com/products/microstation/f/microstation-forum/88449/3dconnexion-spacemouse-settings-for-microstation/250696#250696
https://communities.bentley.com/products/microstation/f/microstation-forum/124672/spacenavigator-not-working-with-microstation-connect-windows-7/379528#379528
José
