I use tab jumps in function windows a lot. When I perform any action I usually call the function window by CTRL + SPACE and then jump with TAB from box to box.
Since CE, especially CE4 some tab jumps don't work in the correct order anymore, e.g. when placing a cell the "active cell" box is highlighted/activated and pressing TAB should move the focus to the next box. Should. But instead it hops somewhere else outside that window. If I put the Cursor in "active angle" everything works as desired. Even SHIFT+TAB jumps back to the "active cell" box.
When scaling elements in V8i I could open the function window and the box "method" was activated. I could switch between items in the drop down menu by pressing SPACE, arrows and ENTER and then TAB to the next box. Now in CONNECT the TAB jumps to nowhere.
Similar behaviour can be seen in many other function windows. Very obviously some programmer didn't do his homework properly. I think I already made a service ticket for that but nothing's changed so far.
I hope this will finally be corrected in CE 12. Just placing an answer so I don't forget to keep coming back to this one until it is resolved.
By the way: I am talking about the GERMAN version here - I don't know about the English version, might work fine there.
David Trejo-Rodriguez: Philippe HALET just confirmed this behaviour in the comment section of his idea for the French version. So I guess it's global. I wonder why Bentley doesn't just correct these litlle nuisances on the fly instead of searching for excuses.
Andrew Bell, Yvonne Lohse - can you please put this on a defect list to be fixed?
You could change the language in "Preferences/Language" to english and try again. In MS CE Updt 13 English, I have the same behavior.
As you say, the standard tab behavior must be the default : it is a standard on all Windows platform (amongs other). Changing it is disturbing.
Philippe HALET
CEO at beCAD a Gold Channel Partner
Bug 654183 has been filed for this issue.
Regie
Thanks a lot Regie, even if it took 4 years ;-)
