Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
MicroStation
MicroStation Forum
Does Microstation v8i make a TrueType of an Microstation .rsc text?
Sign In
Replies
Subscribers
109 subscribers
Views
Users
0 members are here
MicroStation V8i
Fonts
TrueType
Brian Thomas
over 14 years ago
I noticed the first time I use a Microstation .rsc font in V8i I get a message regarding creating a TrueType font? Is this file stored somewhere? Brian Thomas Selser Schaefer Architects
Offline
Phil Chouinard
Wed, Dec 31 2008 1:27 PM
By default, that will be in $(MS_TMP)\GeneratedTTFonts
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
Offline
Josh Schifter
Wed, Dec 31 2008 4:01 PM
in reply to
Phil Chouinard
Keep in mind that the automatically generated TrueType fonts are intended
for use by the WordProcessor dialog. The quality of these fonts is not
likely to be sufficient for other purposes. For example, I would certainly
recommend against using these for creating MicroStation text elements.
HTH,
Josh
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
Brian Thomas
Wed, Dec 31 2008 4:34 PM
in reply to
Josh Schifter
Thanks. I understand the quality level. Brian
Brian Thomas, AIA, LEED AP BD+C
GH2 Architects
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
Offline
Jeff Marker
Mon, Jan 5 2009 12:40 PM
The quality of the generated TrueType font will be somewhat font-dependent. TrueType does not support "stick" fonts well (where the glyphs are made of thin lines, not filled shapes), although some improvements were made in V8i to address this. I generally agree with Josh that you shouldn't substitute an RSC font with this TrueType equivalent, but depending on your needs, they are valid TrueType fonts.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
Brian Thomas
Tue, Jan 6 2009 2:01 AM
in reply to
Jeff Marker
We have a .rsc font that I was trying to get my "excel" reports to match. The Microstation TrueType equivalent works well enough for this usage. Brian
GH2 Architects
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
