After masking a dynamic view attachment the boundary is not showing once the ref file is selected. Modification of the mask is impossible, and the only answer is to draw the elements back in or re-attach the cut.
This is happening with clips also. Any reason? There are many posts that seem to touch on this issue however seemingly no fix is in place.
Microstation V8i 08.11.09.536
Hi Jason,
I know it is a while ago you had this issue but if you cannot modify the reference boundary then this Bentley WIKI will be the solution.
https://communities.bentley.com/products/microstation/w/microstation__wiki/14541/modify-reference-boundary-by-handles
Good luck.
R,
Anders
