batchprocess utility
I try to get this batchprocess running on the command line but I get no resuls. It's just running true the files but does not do the convertion of the AEC objects?
Anny idea?
msbatch batchprocess D:\BatchPocessJob.bprc
BatchPocessJob.bprc
[SETTINGS=bpOptions]
   logFile=_USTN_OUT:batchprocess.log
   cmdFileName=D:\Bt4BPCF.txt
   clearLog=1
   initialModel=-18
[SOURCE=C:\Users\NLCHPR\Desktop\Batch process\Export_01\*.dgn]
[MODEL=:AllModels:]
Bt4BPCF.txt
#  Command file for batchprocess utility
#  This command file was originally copied from $(MS_DATA)cmdfiletemplate.txt.
#  Command file information:
#       - Lines that start with the '#' character are treated as comments and ignored.
convert AcisToParasolid all
batchprocess.log
Processing Batch Process Job: D:\BT4_BatchPocessJob.bprc
Start Time 7-3-2018 15:00:15
BatchProcess: 89 files processed
              Total processing time 0.0 seconds
End Time 7-3-2018 15:00:28
Parents Reply Children
