Accusnap seems to be going crazy.. Sometimes it will snap where it should, other times it just puts it at the cursor.
Here is a video
Possible that it has to do with the DPI settings. Happens with all snap modes
It does look like their was a bit of cursor movement at the end of the video. Most likely causing the loss of the snap point.
I would recommend adjusting the Stickiness to be higher, you can reference the help or the following:
https://docs.bentley.com/LiveContent/web/pub.xql?action=home&pub=MicroStation%20Help-v10&lang=en&docid=FBXExportSettings#addHistory=true&filename=AccuSnapSettingsFeel.xml&docid=AccuSnapSettingsFeel&inner_id=&tid=&query=&scope=&resource=&toc=false&eventType=lcContent.loadDocAccuSnapSettingsFeel&url=/LiveContent/web/search.xql%3Fc%3Dt%26pub%3DMicroStation+Help-v10%26lang%3Den%26action%3Dsearch%26query%3Daccusnap%2520settings&sid=lcSearch.runSearch1520968432071¤tQuery=accusnap%2520settings¤tScope=
We made sure to hold the cursor as steady as possible and the issue seemed to resolve its self after a reboot.
I don't think it was related to cursor movement. It seemed to start when messing with the DPI settings .
I've been having this same problem for few months now. It does not occur every time. Some days it might be ok but sometimes the snap doesn't work. Any advice how to fix it?
I have been having the same issue as well with ABD Connect edition. I have to tentative snap to every point as I just can't trust that the correct point has been selected. Adjusting the stickiness and tolerance settings seems to have no effect.
This is a serious issue for productivity and accuracy in drafting... Accusnap just seems to just have a mind of it's own in CE, and will randomly select a point in open space rather than snap to the highlighted point. Many times I have had to re-model things because elements were not placed accurately once you zoom in to inspect them.
Can you please fix this ASAP as CE offers some great toolsets but seems to have some serious flaws in basic operations like this, (another is crashing when selecting elements in nested references), which prevent me from recommending this software as an upgrade for our company.
Bump to the top as this has not been fixed and have seen it on various other users.
