Hey all!
I am still new to Micro station and VERY new to Batch Process. I wanted to find a way to change the color of one, or more, levels in a reference that is in multiple files. The basic way I was taught to do this in Microstation without batch process was to go into the level manager, select the reference file, then select the level(s) and change the color there. I have read that I want to use the color override keyin to get the result I need but I haven't had any luck. The one I have below was to try and change all the levels in the file but it did nothing.
I am still a noob at this so if anyone has any good youtube tutorials or blogs that I should read up on please let me know. Any help is really appreciated.
level set override color on file:RPLN-EX.dgn"* *level set override color 168 file:RPLN-EX.dgn* *
why not go to the reference and change it there ie levels on off and change colours... save settings then open one of you drawings and the changes to te reference should now be visible..
Lorys
You would replace the "all" inlevel set override color 168 file:RPLN-EX.dgn allWith the name of the level you want to modify. You would end up with a command that looks likelevel set override color 168 file:RPLN-EX.dgn Ex_Pvmt
If you have a naming convention that would allow you to select a group of levels (like Ex*) you can identify them that way. That would give you a key-in likelevel set override color 168 file:RPLN-EX.DGN Ex*
A batch process command file is just a text file of Microstation key-in commands, so you can test each command in a drawing file before you include it in your batch process file to make sure it does exactly what you want. The last line you may want to consider for you command file might be FILEDESIGN - that's the key-in for "Save Settings".
MaryB
Answer Verified By: Michael Drew
Yeah that is perfect. So after a little more messing around I see that have the Level Overrides on affects references that I do not want to change. Is there a way to change the color of a reference by level instead of an override?
Nevermind I figured it out! It was literally just replacing override with bylevel. I went with override cause I thought it was the only way to change color by at my office we prefer changing the by color level in references.
level set bylevel color 168 file:RPLN-EX.dgn all
I am using just the level set override color off all, works great on either Override or bylevel. My need it to only turn off say Level 2 override color or 2 & 3 I could really use the other ones on. I hope it is ok to reply with a question on the same issue ?
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
