Microstation Powerdraft Connect Edition Update 7 - Version 10.07.00.39
When I open the Text Editor dialog box, it always opens with the text editing area too small to see any text. I can resize it while using it, but when I close it to place text and then open the dialog box again, it reverts back to the same size. Anyone know how to fix this?
Layne
Was this a recent occurrence after it was working ok for a while or is this a brand new installation or update?
This appears to be either a graphics display issue or possibly a problem with your User Preference File (UPF).
I am thinking to first try resetting the UPF and cleaning out the temp files.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8978/how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
If this does not work then it might be worth checking whether your system has a newer graphics card driver.
http://communities.bentley.com/products/microstation/w/microstation__wiki/13543.troubleshooting-graphics-display-issues
