Hi, I'm trying to install Bentley View 8i (SELECT SERIES 4) 08.11.09.829. The installation appears to work fine until it starts downloading Microsoft Visual Basic for Applications Core which stays at 0% for several hours and doesn't proceed. Screenshot captured below:
Are MS VBA Core and Localized some pre-requisites I can download separately or can someone email me? I saw other similar thread and tried the recommended solution to go to connection center and click on software downloads to get the required VBA installation file as shown in the screenshot below:
But when I click on Software Downloads, the message appears on next page to deny access to SELECT support services as shown below:
Is there a way to get access to SELECT support services or to download and install MS VBA separately so my installation of Bentley View gets completed?
Naveed
Good day, please I will be happy if someone can send me a link to download Microsoft visual basic for applications core and Microsoft visual basic for applications localized. I don't have access to download through my support.
Hi Bartholomew,
Good day! I still met those issues. So Could you please send me a link to download Microsoft visual basic for applications core and Visualization context.
This discussion is over 4 years old and for MicroStation V8i SS4, which is no longer supported by Bentley. This would be the reason you may not be able to locate these Prerequisites on the Software Download page. We would strongly recommend that you should be upgrading to the supported versions of MicroStation CONNECT Edition. If you require this old software you should raise a new Service Request to technical support and we will look into providing these Prerequisites using another method.
Desktop Applications Support Policy
Bentley.com - Technical Support
Do a repair of installation and it will fix issue with VBA. It is one of beauty of VBA for applications that time to time Microsoft updates can mess with it.
