Is there a key-in that will change a model from a sheet to a design?
In v8 I had a little vba recorded that I would batch process on flattened files to change the sheet to design, so that when converting to dwg after, all info was in model space.
As the model properties dialog has now been consumed into the general properties window this vba no longer works, and for some reason the macro recorder wont record the steps taken when I change this in thge properties window.
Many Thanks Leonard, works like a dream. I have managed to edit to apply to any sheet.
Is there any way i could edit though so that when it renames the sheet it will rename it as per the filename?
Thanks again
