I'm finally going to get serious about migrating to Connect!
Easy question- Can we modify the basic right click menu? I really need to add the Element Selection tool to that.
Yes the following article outlines the process to remove some menu items but you may find helpful as a reference:
https://communities.bentley.com/products/microstation/w/microstation__wiki/14060/context-menu-too-long
The steps I would recommend would be as follows:
1. create a dgnlib where your customizations will be stored.
2. store the dgnlib in a location to be read by MS_GUIDGNLIBLIST or edit the variable to read the file
3. Use the following link as a reference for the customizations you want to add:
https://docs.bentley.com/LiveContent/web/pub.xql?action=home&pub=MicroStation%20Help-v10&lang=en#docid=CustomizeDialogContextMenusDialogSection&addHistory=true&query=&scope=&tid=&filename=CustomizeDialogContextMenusDialogSection.xml&resource=&inner_id=&toc=false&eventType=lcContent.loadDocCustomizeDialogContextMenusDialogSection
4. restart MicroStation and check if the dgnlib is being read and if the customizations are followed.
*edit link updated
Answer Verified By: Bob Rayner
link doesnt work for me just loads connect edition help menu...!
Lorys
Thank you. I have updated the link
Odd behavior, 1st time I clicked linky got a general Connect help page. 2nd time link took me to the intended information. Thanks!
Bob Rayner said:Odd behavior, 1st time I clicked linky got a general Connect help page. 2nd time link took me to the intended information. Th
Yep me too but now after he fixed it,,,,
but before it always just went to stupid connect help! no matter how many clicks
