We get DXF files over that have been created in AutoCAD and in theory we should be able to open them in Microstation but 5% of the files that are sent over we can't seem to open in either.
I have tried to open in AutoCAD, Fusion 360 and Microstation but to no avail. I have also tried to add the file as a reference but that won't work either.
The error that comes up in Mircostation is 'Unable to open design file. Please contact your local site administrator or technical support provider for further assistance.' and it just crashes AutoCAD.
We can, however, open in it in QGIS, but can't extract the co-ordinates.
I have gone through every forum I can find but can't get any of the solutions to work.
Versions are:
Microstation - Microstation V8i (Select Series 3) [8.11.9.357]
AutoCAD - AutoCAD 2018
Many thanks!
it is AC1027
Anton,
In Autocad there is a recover command inside Drawing Utilities that you can use to correct some errors in DWG or DXF without opening the file. Did you tried this?.
José
If ACAD 2018 won't open them, there is something wrong with the files. Gonna interweb guess it's some type of application software that has created these.
Then the DWG is corrupted and you'll need autocad 2015 - 2017 to recover / repair it without opening it as Jose mentioned..
Ideally you should ask the original source to open their version and save it as DWG 2014... and ask for them to open that and see it is not corrupt before they resend it to you...at least they can tell whats missing or not exporting before they send it.. if you try to use the recover some critical data may be lost that your not aware of... this very high risk your organisation trying to fix an external source file....my manager would never allow this .. he'd insist on a resupply of the DWG file and a pdf to compare with as when you convert to mst some things can get lost....
Lorys
The actual acrap command is Audit, I wish I didn't know that...............
