Enter Data Field
I am using Microstation Connect v10.4.0.46.  I have been trying to edit ENTER DATA FIELD in a cell. No matter what I do it doesn't seem to work.  I chose the Fill-in Single Enter-Data Field command.  I get prompt to Identity element. I identity the EDF element in the cell. I get a dialog box with text boxes for Length, Value (which has the value of EDF I picked), drop-down for Justification with commands for Drop, OK and Cancel. I over-write the Value text box and click on OK.  The dialog box disappears and the value remains the same as it was before,  Is there something I am doing wrong?  I tried the help, but that didn't help.  I would like this to work the same way as it did in Microstation 8i.  Does anyone know how this will work.
Parents Reply Children
