Microstation V8i (SELECTseries 2). I have a drawing in 2D that consists of multiple elements. I want to have the whole drawing as one entity so i can copy the drawing and paste it elsewhere as one drawing. Your help is appreciated.
Rajakrishna Sudhakaran said:I want to have the whole drawing as one entity so i can copy the drawing and paste it elsewhere as one drawing
The usual approach for that purpose is a MicroStation cell library or a reference. I see that José is describing the reference route. Here's how to make a cell library from your existing file...
.cel
MS_CELL
Rajakrishna Sudhakaran said:Still selecting individual elements.
Are they locked?
Check Properties:
You can use CTRL+L (to lock) and CTRL+M (to unlock).
Or is this a reference file?
José
Drawing is unlocked. No, not a reference file
Rajakrishna Sudhakaran said:Drawing is unlocked. No, not a reference file
Have you tried using CTRL+G with less elements?
I've seen this happend especially by the look of your screenshot 2D output that came throught 3D. This cause your drawing to have a lot of elements and CTRL+G can't make the group, specially using SS2 which is now somewhat older version of the program (2013).
Depends what your need is, but by the look of it the best way is to work with references. Or update your program version.
^The drawing will need to be in a model type Design for that to work.
If you tell us what you want to do with the thing, we may be able to make better suggestions. There are certain advantages to using the Group command.
This seems like a candidate for referencing, depending on what you want to do.
