Good Morning,
I am trying to figure out how the previous administrators ran a .txt file into a .dgn so that it will go through all the levels, draw a line for that level and then place text of that level's name. Here is the beginning few lines of the .txt file. I have tried @C:\path\file_name.txt in the keyin but it doesn't seem to work. Nor does starting the Place Line command and then running the keyin.
I appreciate any help, thanks.
God bless,
David
I'm sorry all... I didn't check my path! I was missing one underscore. It is working fine now.
Thank you all for the help, it is very much appreciated!
David Sullivan
Engineering Software Support Engineer
MS V8i SS2 v08.11.07.492
MS ORD-CE v10.09.00.91
Answer Verified By: David Sullivan
I removed my mesage right after I had placed it since I immediatly noticed Mary beat me to it.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
