MicroStation CONNECT Edition Update 8 stopped working when Windows 10 Spring Creators Update was installed. Someone else happened to him?
vpastor said:when Windows 10 Spring Creators Update was installed
as far as I know Spring Creators Update has not been released officialy yet and and RTM Build is available in Preview Ring only, so it's a question whether Update 8 is certified for this Windows 10 version. Also probably very small amount of people tried preview releases to be able to share their experience.
vpastor said:MicroStation CONNECT Edition Update 8 stopped working
It tells very little. What does it mean "stopped working"? Is there any error message, exception log or something else?
vpastor said:Someone else happened to him?
I have heard about no such problem yet.
Did you try to repair the installation?
With regards,
Jan
Thank you very much for the answer ... actually the update was for the fast ring, try the repair but it did not work either, There was no error message just try to load the application but it does not respond. I have returned to the previous version of windows and will try later. regards
If the repair has not worked for Update 8 you might consider upgrading to Update 9 which has just been released.
vpastor,
were you running iplot as well ... pretty sure there is a major problem with iplot when the spring creators update is installed. Particularly on the 64 bit versions.
Mark SegelquistKDOT CADD Administrator
GEOPAK user since 1990
"...the status quo is not a stream, let alone a 'mainstream'. It is a stagnant swamp. It is the innovators who carry mankind forward." - Ayn Rand
Mark, your previous post here was split out to be investigated from the Plotting and Printing Forum. I would suggest anything relating to IPLOT be discussed there rather than the MicroStation forum.
https://communities.bentley.com/products/microstation/microstation_printing/f/printing-and-plotting-forum/151512/issue-running-iplot-with-microstation-connect-edition-update-9-after-windows-10-spring-creators-update-was-installed
