MicroStation CONNECT Edition Update 8 stopped working when Windows 10 Spring Creators Update was installed. Someone else happened to him?
I am trying to find out if he is running iplot as well to see if the is issue is related so why can't I do that without some moderator overreaching and moving me.
Mark SegelquistKDOT CADD Administrator
GEOPAK user since 1990
"...the status quo is not a stream, let alone a 'mainstream'. It is a stagnant swamp. It is the innovators who carry mankind forward." - Ayn Rand
If you wanted to ask the specific person that posted this discussion that is fine but to try to get answers for your issue it has been separated for others within the Plotting Forum to assist you. You might also like to raise a Service Request to our Plotting Specialists via the on-line Service Request Manager.
In case it helps, I was not using iplot.
I think it's a problem with the windows 10 version, whenever they update the operating system they damage something. We will wait for the update 9 in Spanish to see the result. regards
I was sharing information that I though might lead to what was possibly causing his problem Mr Bell because I though this being a community that would be a good thing to do. I have worked supporting and administering Bentley products here at the DOT for most of the 34 years I have worked at the dot and I am well aware of my option to file a service request thank you.
Please don't reply .... I'm Done!
Looks like that Windows Version will start to rollout today or tomorrow to the consumers. Version 1803 or Build 17133. Hopefully vpastor's experience is an uncommon one ;)
