When working on a project, I used the "Fit View" tool. When used, the view expanded ridiculously far. I am not sure what the issue is or what setting can be used to modify this. I tried changing what the files used for the view but that doesn't seem to make any difference. Any help would be appreciated. I have attached the file that we are having problems with also. The drawing that has been done in this file is in view 6.Fit View Issue.dgn
You have an element in the file that is far outside the working area:
You can delete the element if it is not supposed to be there.
How did you find this? I am still relatively new to Microstation and not sure what tool you used for this?
Play with it, you'll figure it out. Sometimes selecting the elements will help. When you fit a screen stuff will generally position consistently, if you can see one part, you can zoom in on the other part. There is also a fence mode that will allow you to delete the void, but usually we like to see what is there.
You also have a text element that has no text in it. Which shows up invisible.
Those elements outside your working area, hence you can not zoom in on them. But you can alter their location by editing X and Y through the element information dialog.
If you want to select everything that is outside your regular field try the following.
Select everyting in the model by using the select tool and press the little globe icon. Or keyIn CHOOSE ALL. (24 items total)
Then deselect the items that you want to keep (title block and print border) (22 items).
You now have 2 elements in your selection set, which are outside your working area. You can inspect them with the element information dialog or just delete them.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Particularly when you have larger files the Selection operations may take a while (I've got a lot of those from third party). The good old fence operations come in handy here. Draw a fence around everything you want to keep and choose the option "Outside". Then use fence delete. You can even send the content of the file to another file through a fence operation. That has the benefit that you get a "new" clean file with all the settings of your current file but just with then content you need. In particular files from third party sources can contain a lot of unnecessary "legacy" information that you can quickly get rid of this way.
