When working on a project, I used the "Fit View" tool. When used, the view expanded ridiculously far. I am not sure what the issue is or what setting can be used to modify this. I tried changing what the files used for the view but that doesn't seem to make any difference. Any help would be appreciated. I have attached the file that we are having problems with also. The drawing that has been done in this file is in view 6.Fit View Issue.dgn
Test deactivating the default level, that level has some element that makes the visualization go crazy.
TThat level has two elements that appear in the level manager but in level properties there is nothing, so I would recommend you select by level and eliminate directly. I'm sorry translated by google
I am kicking myself for spending that much time and not thinking of that simple of a solution. Thanks for the help!
This method actually helped! I was not able to locate the elements placed outside the working area by selecting all elements. Deleting everything outside the fence worked like a magic. Thanks!
You are welcome. Good to know that these older threads still are useful.
You can also try key-in:"mdl load fixrange"But for some reason sometimes it doesn't fix wrong ranges and need to delete using fence.
