Hello Forum,
When ever I try to create a link between Excel and Microstation using the "Linked to Design File" tool, I get the attached pop up.
I just updated from MicroStation V8i (SELECTseries 2) to MicroStation V8i (SELECTseries 4) and that's when I started to have the issue.
Every time I try to update or insert a new link from an excel sheet (while I have it open) it will give me the same issue.
Any possible answers?
Thanks in advance,
CM
In case someone finds this post, had a similar issue appear in MS 17, ORD 10.11 and 10.10 . Check the Advanced Options in Excel and uncheck the "ignore DDE links".
colliersengineering.com
