Is there a process to export multiple files in KML ? I would't export each DGN one by one and the batch converter does not have this file format.
Thank you
I found a solution. Use Batch Process with :
GEOCOORDINATE ASSIGN YourCoordinateSystem$ EXPORT GOOGLEEARTH $(basename(_DGNFILE)).kml
Good to hear that you were able to locate the appropriate keyins for your Batch Process.
Andrew Bell said:appropriate keyins for your Batch Process
1 - I believe this could be easily add in the Output Format of Batch Converter as Bentley did for a lot of other formats. Some less common that of KMZ.
2 - And why the need of a scrollbar if we have a large monitor/window? This scrollbar as all scrollbar should only appear if we have more options that the space available. This same issue happen in the past for other windows, and Bentley corrected this.
José
I am trying to modify this Batch Process to convert DGN to KML inside of ProjectWise. This works great but writes the KML to my local workstation. Is there a modification of this that will write the KML file to the same directory on ProjectWise as the source DGN file? Thank you for any help!
Good comments José! Got a chuckle for the scroll bar thing. I've got about a dozen UI bugs using Connect. Some scroll bar applications will skip or hide a line as you scroll down/up using mouse click.
