Hello good MS community,
Here's a question taht I've been trying to figure out, or maybe know if you're able to do it.
When you place a filled shape, such as rectangle or circle, you always get it filled, even when you're selectiong tyhe Fill Type: None.
Is there a way to just make the rectangle or the circle without any solid filled pattern?
I'm using AECOsim CONNECT Edition Update 2, but this is mostly a MS issue.
Yup. this has happened to me since the v8i version
Hello BobI'm aware of that but sometimes you need the hidden line and you just need the closed shapes to be hollow.
Thank you David,
I was thinking suspecting the same, but I wanted to be sure.
I even found on this wiki that you just simple cannot make them hollow.
communities.bentley.com/.../shapes-display-as-filled
You can even have more display options, to make display style override per each elements, so you can have each element display as you need.
José
