I'm attempting to change the dimension lines and text color. The settings were set to Inherit color and I can't change this (not sure what I have missed). The goal is to use ByLevel for the dimension color. What I have attempted is select ByLevel for the color under Dimensions Lines and Text. Since that did not work I also tried by unchecking Color for each. What I get for either scenario is the same color no matter the level I'm on. Please advise an inexperienced MicroStation user.
Thank you,
PowerGeopak SS4, v08.11.09.878
There are a number of questions to understand how you have placed the dimensions.
Maybe you could supply an example design file or a couple of screen captures to show how you are trying to perform this.
Yes using dim styles. Attached are some screenshots.
Missed the question about selecting Active Color as ByLevel, the answer is yes I tried that but it did not work either.
Would you be able to supply an example DGN file so we can see how you might have placed the dimensions.
Attached. I removed the references and left just the dim and place note
SHT-DRAIN-PLAN05.dgn
