I'm attempting to change the dimension lines and text color. The settings were set to Inherit color and I can't change this (not sure what I have missed). The goal is to use ByLevel for the dimension color. What I have attempted is select ByLevel for the color under Dimensions Lines and Text. Since that did not work I also tried by unchecking Color for each. What I get for either scenario is the same color no matter the level I'm on. Please advise an inexperienced MicroStation user.
Thank you,
PowerGeopak SS4, v08.11.09.878
Thanks for the example design file. It appears that you need to define the ByLevel color for the text within your TextStyle being using in this Dimension Style, IDOT032.
Andrew, thanks for the help. after 10.5 hrs working I decided to go home.
I attempted (I think) to define the text to ByLevel for the color by Selecting Color and selecting ByLevel. This did not change the appearance. I have unchecked the Color for the text but same results. Attached are screenshots of what I have setup. The second attachment are the results. As you probably can see the color of the text and leaders should have been 35, with 0 line weights but I'm getting color 45 with a line weight of 3.
Looking at the file you sent - you have the color for the dimension lines and the extension lines set to color 43 and the text and terminators color is not set. You also have the dimension set to go on level "Design_PR_Roadway Dimensions" . If I look at the textstyle used , it does not have its color set so whatever color is active is used.
Are you attempting to change an existing notes color ? or are you attempting to change what will be placed ?
I am only going by the file you have provided.
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Robert Watson
Tim, you are correct about the smbology settings in the file I sent. I have been trying various settings to get this to work but have not been able to. I have not found where to change the level from Design_PR_Roadway Dimensions to use the current level.
At a minimum I would like to have all new notes and dimensions use the active level, color and line weight. If the older items changed to that would be great.
I inherited this from someone else that had zero experience with MicroStation, and I'm not much better. We are both Civil 3D users.
Thanks for any advice you can provide.
Tim, I was able to change the level my dimension were going to thanks to you mentioning what it was set to. Thanks for the help. Looks like I can get all new dims to appear as they are suppose to. I can modify existing ones as needed.
