Dimension Inherit
I'm attempting to change the dimension lines and text color.  The settings were set to Inherit color and I can't change this (not sure what I have missed).  The goal is to use ByLevel for the dimension color.  What I have attempted is select ByLevel for the color under Dimensions Lines and Text.  Since that did not work I also tried by unchecking Color for each.  What I get for either scenario is the same color no matter the level I'm on.  Please advise an inexperienced MicroStation user.
Thank you,
PowerGeopak SS4, v08.11.09.878
  • I some times have had to  use  LD=<the levelname I want dims to go on> so if the active  level was "DIMS" keyin  LD=DIMS
    forces all new placed dims on to that level called "DIMS" in that file ... this is  very old keyin but still works in v8i .. I'm sure some where  in the advanced settings there is the level option but this one usually  fixes  it when they havent been defined properly...
    Lorys
    click link to PM me
