The linetypes in a reference file that shows correctly in all my sheet files except one. I cannot figure out what might be causing this. I have compared the reference file (presentation settings, the toggles, the Global Line Style Scale, Detail Scale, Scale (Master:Ref)…), Model information (type is sheet, scale, Propagate Annotation Scale, and global line style scale), and also compared view attributes. I’m uncertain what else to check to get the linetypes to display the same as in the other sheet files.
PowerGeopak SS4, v08.11.09.878
Is it possible for you to supply the master : reference file(s) so we can try to locate what may be the cause of your issue here?
Are the file formats DGN or DWG or both?
When you say Line Types is this relating to DWG format or is it Line Styles you are talking about?
Maybe some screen capture would help as well.
