CE update via deployment
I have setup a series of MS CE8 and PD CE8 via a deployment using the /layout option.  The deployments were deployed and all worked OK.  I then created a new CE9 deployment and run it via the exe to update the CE8's.
NOTE.. I did not use the connection client to do this.
CE8 was updated to CE9...  however, as soon as i start CE9 it crashes.  I am unable to open a dgn file in CE9.
So... I uninstalled CE9, deleted the folders and ran the deployment again and all is OK.
Conclusion... the deployment update process doesn't work.
Ian
Parents Reply Children
