It would great if the Range fields reported the highest and lowest ranges instead of 'Varies'.
Hi Dominic SEAH,
The Range Low / High does not show because you selected multiple elements.
If you go down the pick list and select a specific element then the Range Low / High will displayed.
Let me know how that works for you.
Kind regards,
Anders
What do we do to get the high and low of the whole selection, not just the individual elements?
MaryB
Anders Svensson OMahony said:The Range Low / High does not show because you selected multiple elements
I think that the OP wants the low/high range of the chosen elements as if they had been grouped.
Yes, I know. Not very useful.
Getting the extreme is really useful for a lot of uses. I think that Catia has this as a standard calculation expression.
We were recently asked to look at a drainage channel that was quite long. The surveyor gave us a collection of lines, points and linesteings. We needed to establish the lowest point in the gutter, quickly.
