Connect to browser doesn't work I get this message "error connecting to external browser. Restart Engineering Links".
How to actually restart the e-links?
Found out that Microstation has to be run in administrator mode for this to work but now executing "mdl load webbrows" in key-in Microstation crashes instantly. This feature didn't work correctly in v8i either but now it is even worse.
Hi Oto :
Please share the crash logs. How to quickly find and collect Exception logs and Minidump files
I tried “mdl load webbrows” and “mdl load webbrows google.com” in MicroStation Connect Update 9 and it works."Connect to Browser" also works.
MicroStation Connect Update 9 started in normal mode.
Could be something to do with your access rights.
Regards,Leonard Jones.
Hi Oto,
I get same result as Leonard.
Will you please let us know which is your default Internet browser?
~ASN
Microstation CE Update 9. Default browser is Firefox.
Exception logs uploaded to secure upload. Seems in CE edition these logs contain too much personal data.
How to enable web browser logging to WebBrowse.log? This variable should be set MS_WEBBROWSLOGGING?Found one under documents not sure if it is from CE.
WebBrowse.log
On same computer v8i version works but for some reason it opens Iexplorer window.
