My pc did a windows update last night and this morning when I logged onto CC it tells me that there is a MicroStation updated (CEU9) available for install. I already have CEU9 installed!!
Tamicca. Thanks for this.
So can anyone on this forum shed some light on this issue. Any help would be appreciated.
Hi Stuart,
Can you post a screen shot of the About MicroStation dialog that you currently have installed? I'm assuming it would be 10.09.00.23 since we did push out an update to 10.09.01.01, just as a confirmation. However, if you did do the update to 10.09.01.01, then we'll have to investigate further.
Dan
As requested.
Thanks Stuart for the screen capture to confirm the version. The CONNECTION Client is correct in that there is an update to MicroStation CONNECT Edition Update 9. It resolves an issue with the background maps option not appearing in the View Attributes. This will update 10.09.00.23 to 10.09.01.01.
OK thanks for the information. What's interesting about this is that we are not getting updates to updates. So is this CEU9A?
If I update using CC will this keep my custom location, or do I need to use a download?
