could we finally get decent control of what page is attached when using multipage pdf as raster reference? no matter what page I click in ref file preview window, there is still page No.1 attached.Acad has it since v2010
thanks
Hi Peter,
as Maria wrote, MicroStation has supported multipage PDF for quite a long time. I don't recall exactly when this feature was added, but e.g. V8i supports it already:
With regards,
Jan
Answer Verified By: Peter Tegza
thank you both, I never tried this right-click. and now another question, is there way to change the page once the PDF is attached?
/pt
Peter Tegza said: is there way to change the page once the PDF is attached?
As Jan show you, when you attach a pdf file the first dialog you'll get to see is the Raster Attachment Options. You can RMB inside the link path, there you'll have the same option to change the page.
If you're asking after the PDF is attached you can still change the page through Raster Manager\RMB on top of the desired file and you'll get the option Change Page...
Strangely enough if we go to Properties\Image\Page Number\ we can't change the number... There should be an Enhancement for this.
For your information I've ask for a resizable preview window that would help us to select the desired page more efficiently. That turn to Enhancement 407493, but more than 2 years have passed, and so far no news.
https://communities.bentley.com/products/microstation/f/microstation-forum/118167/ce---pdf-attach-preview-window
José
thanks Jose
