I am searching for a while how to move the whole drawing including the References near to the basepoint (0,0).
I am able to select everything, click on the move button and I am able to move it.
But I am not able to just fill in XY=0,0 , it is not working during the move action.
Thanks!
what are the exact steps you are doing ?
Timothy Hickman
Main: 877 627 3772|
1. Opening a DGN file with all the references.
2. Tools->reference manager
3. Turn on Locate, for all the reference files
4. Click on element selection
5. Draw a square around the whole drawing, including the reference files
6. Click on Move
7. Now I am stuck
I can move the whole set by first selecting a point and then moving the complete set.
What I want is:
I want to just fill in XY=0,0 so that the whole set will moved to the basepoint/orign (0,0).
Tried:
Key-in and filled in XY=0,0, this does not work.
It looks like a normal 2d file. maybe I need to try also: XY=0,0,0
can you do screen shot of the mstn ref manager and let me see everything especially the x, y values at the bottom......
BTW why do you need to do this? ... cant you just draw a box in an empty file with one corner at 0, 0 then open your ref file draw your box around all the objects then return to the box file and ref attach the ref file by top no world coinc and place it near you box then refine the movement thru move ref pic lhs of box in ref and move to lhs box at 0,0 in active drawing...
Sounds very autocady trying to use copy by insertion point technque...
Lorys
The move command requires FIRST the Point to move FROM - then the Point to move TO. Sounds like you want it the other way to work.
After your # 7. microStation asks you to to define the Point to move FROM. You Need click at that Point here.(Check the what microStation asks you to do in the lower left corner)
Now all the selected stuff should be Floating at the Cursor.
Then microStaiion asks you to define the Point to move TO. If the keyin window is open you can keyin XY=0,0,0
Also AccuDraw is active now. That means that you can use the AccuDraw Shortcuts. I prefer using AccuDraw over the keyin window for large number of reasons....
So instead of the keyin window you can instead:Press "P" - this opens a temporary window for the Input of a coordinate Point - if you just key 0,0,0 there all your selection should land at what you call the basepoint (called global origin in microStation)
This works perfect with one file, but this does not work with the references, (locate is on).
In Reference Manager, do you have "Treat Attachment As Element" checked on for all reference files? If not, you will not be able to move the references along with the elements in the active file.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
I agree with mwlong - look at the "treat attachment as element" option for the references.
Thanks, this does do the trick:)
