How to move the whole drawing including their references to the orign / basepoint
I am searching for a while how to move the whole drawing including the References near to the basepoint (0,0).
I am able to select everything, click on the move button and I am able to move it.
But I am not able to just fill in XY=0,0 , it is not working during the move action.
Thanks!
  • It looks like a normal 2d file. maybe I need to try also: XY=0,0,0
  • can you do screen shot of the mstn ref manager and let me see everything especially the x, y  values at the bottom......
    BTW why do you need to do this? ... cant  you just draw a box in an empty  file  with one corner at 0, 0 then  open your ref file  draw your box around all the objects then return to the box file and ref attach the ref file by top no world coinc and place it near you box then refine the movement thru move ref  pic lhs of box in ref and move to lhs  box at 0,0 in active drawing...
    Sounds very autocady  trying to use copy by insertion point technque...
    Lorys
    click link to PM me
  • The move command requires FIRST the Point to move FROM  - then the Point to move TO. Sounds like you want it the other way to work.
    After your # 7. microStation asks you to to define the Point to move FROM. You Need click at that Point here.(Check the what microStation asks you to do in the lower left corner)
    Now all the selected stuff should be Floating at the Cursor.
    Then microStaiion asks you to define the Point to move TO. If the keyin window is open you can keyin XY=0,0,0
    Also AccuDraw is active now. That means that you can use the AccuDraw Shortcuts. I prefer using AccuDraw over the keyin window for large number of reasons....
    So instead of the keyin window you can instead:
    Press "P" - this opens a temporary window for the Input of a coordinate Point - if you just key 0,0,0 there all your selection should land at what you call the basepoint (called global origin in microStation)
  • This works perfect with one file, but this does not work with the references, (locate is on).
  • In Reference Manager, do you have "Treat Attachment As Element" checked on for all reference files? If not, you will not be able to move the references along with the elements in the active file.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
