i cant get 3d linestyles to display the element created by extrusion solid as per Creating a 3D Line Style - Jersey Barrier online video
the smart solid elements are working, i am using Bentley Connect update 9
Hi Richard,
richard villis said:i cant get 3d linestyles to display the element created by extrusion solid
I haven't tried, but I bet that 3d line styles do not work well with the new boolean operation kernel implemented in CE.Try to convert your parametric extrusion solid to a smart solid using convert solid in Search Ribbon or under Solids\Solid Utilities\Convert Solid.
If this helps then an enchantment should be placed for this issue.
José
Hi José
Yes that worked thanks for that, my 3d linestyle works now
problem now is converted solid does not render, but the smart soild lifting lugs do render
see attached
Richard
richard villis said:problem now is converted solid does not render, but the smart soild lifting lugs do render
If the original question was answered please follow forums best practices and close this with "verified answer" on my suggested answer and create a new forum question:
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
Thanks and regards
