I am trying to delete a duplicate model. Basically it doesn't show in the list of model (REFER IMAGE 1) but it shows in where you can switch between the models (Bottom left drop down menu, next to views, REFER IMAGE 2). How can I delete that model which does not exist at all.
IMAGE 1
IMAGE 2
What you are looking at in Image 1 is a list of the Design and Sheet Models created in the design file you have open.
Image 2 is showing a list of View Groups that relate back to those Design and Sheet Models. They are not the actual models.
You can make change to the names and delete any View Groups by click on the icon next to the pulldown box "Manage View Groups".
https://communities.bentley.com/products/microstation/w/microstation__wiki/31565/how-to-change-the-names-of-your-view-groups
Answer Verified By: Jaimin Patel
Thank you very much Andrew, it helped a lot. Solved my problem and also exposed me to the opportunity to use this function while working on models! Thanks a lot.
