I have been adding co-ordinates to a site plan in SS4, using the Label Coordinates tool. If I close and re-open the file in CEU9 the Label Coordinates tool doesn't work, in that co-ordinates are not added to the model. They don't appear at the end of the cursor for placing.
Look on level Default. That entire set of tools is wonky in Connect.
Not something else that doesn't work in CE?
Just tested this and you are right. The coordinates go on level Default totally ignoring the active attributes. Assume that Bentley are aware of this.
stuartw said:Assume that Bentley are aware of this
Don't assume! File a service request.
Done it!!
