Using the label tool to place labels calling off space info (room names, numbers areas etc)
The cell I have created has 3 separate text elements, each on different levels for different displays and drawings, however, when placing the label does not honour these levels, instead placing all elements on the same (active) levels. Is there anyway to get the label to honour the original levels?
Duncan Gammie said:Using the label tool ...
Of which MicroStation version?
Hi Jon,
This is for Connect, currently on U99
There is an outstanding Enhancement 314660 as mentioned in this thread https://communities.bentley.com/products/microstation/f/microstation-forum/111738/labels-vs-cells/340969#340969
Thanks for the info Carl.....
As usual though, is anything actually being done about this. Over 3 years since the enhancement was filed!!
Enhancement # 314660 appears to be approved for a future release of MicroStation CONNECT Edition. For updates to this you could log a Service Request which can be linked to this enhancement.
