Parametric cell - door swing arc
Just looking at parametric cells in Connect U9. I've made a simple 2d door symbol with a couple of variations but the arc for the door swing won't flex when I  change the leaf / opening size. I have it constrained to the leaf and jamb. Can't see a way to specify a radius as a parameter.
Duncan
  • Have you tried adding a Dimensional Constraint to the door swing ( Arc ) and assign a variable for the Radius. For Example
    See also
    https://communities.bentley.com/products/microstation/b/microstation_blog/posts/new-in-microstation-connect-edition-update-5-choose-between-diameter-and-radius-constraint
    Answer Verified By: Carl Myhill
