When I draw an element, it creates a duplicate element with the same element ID? Happening on multiple computers with the same DGN.
www.certainty3d.com/downloads/BrokenDgn.mp4
Geomatiques_Gidion0.dgn
Maury said:When I draw an element, it creates a duplicate element with the same element ID?
Is the DGN model self-referenced?
Answer Verified By: Maury
It is, you are a genius :)
In what case would someone want to do this?
you have your own dgn referenced
regards !!
Could be some purpose. But my guess it's just user error. The CAD technician is slowly becoming a dinosaur. Many highly placed professionals simply don't take the time to learn how to use their toys.
Connect r17 10.17.00.209 self-employed
The most common use of self references I've seen is when you want elements to print more than once.
In mapping applications you have multi-lane highway representations that are generated from a single line. A thick line is printed first, then using the same line in a self reference attachment you print a thinner version in a different color. Depending on the representation this might be several layers deep. Pen Tables, or Design Scripts control the color and thickness depending on the reference attachment.
The standard US Interstate Highway representation on most maps is a thick black line first, then a thinner red, yellow, or green line on top of that, then a thin black line in the middle. One line plotted three times with three different thicknesses.
This was done long before the introduction of the multi-line element, but even then there are limitations to multi-lines.
Rod WingSenior Systems Analyst
