I'm worried about an obvious slowness of the connect edition (it is indifferent the uppdate I have verified that from 6 to 9) compared to the v8i in the management of files with many references (over 50) and great complexity. the speed of file opening, creation and management of graphic drawings of the V8i SS4 is incomparable at the moment.Knows someone the configurations to made the connect speed management files at least similar to the v8i?Thanks for any support yol'll can give me.
Daniele Poddafor Cad CONNECT (Gold Channel Partner Italy)
I wanto to provide an upgrade in this thread
In a file with 40 references (see the attach) I cleaned up every single file of references not found or useless, I converted in every file all Acis in Parasolid, another annoying thing for Connect.
With these changes:
V8i SS3 1st open file 45.58 sec 2nd open file 19.08 sec
CONNETC UPDT 9 1st open file 57.02 sec 2nd open file 24.12 sec
Another problem is about the PDF print, the slowness of CONNECT in raster PDF print is unsustaineable, so I solve only changing towards low resolution the point/inch rapport into the driver config.
The timeing is not terrible but need a check of single file before opening with CONNECT Edition. Is my opinion that this should be automatic to not scare the users upgrading to Connect
