Hi Risto
Try changing the colour to ie Red, does it show up. it might be the fact you are using a RGB similar to the background of the text dialog
Text colour is red, but i can´t see any text in the white editor. I can edit it, but i do not see it. In drawing area the text changes when I quit the editor.
Hi Risto,
What MicroStation version are you using and in what operating system?
is this happening in every file or just this one?
Can you upload the file for our review?
Maria
Maria Garcia
MicroStation CONNECT edition update 8 - Version 10.08.00.37 and Windows 10.
It happens in every file.font test.dgn
This may be a graphics display issue. You can refer to the following:
https://communities.bentley.com/products/microstation/w/microstation__wiki/13543/troubleshooting-graphics-display-issues
A similar case was brought up in the following post:
https://communities.bentley.com/products/microstation/f/microstation-forum/136640/connect-edition-update-5-text-editor-issue/451730#451730
