MicroStation Update9 is being packaged for deployment here via SCCM.
SCCM installs applications using the system account and not a standard user.
Can the 'No GUI' deployment installation be run without the Connect Client being started during the install?
We would like the users to run up the Connection Client after MicroStation is installed.
Hello Larry,Please follow these two wiki articles from Bentley Cloud and Web Services Community: Installation - Silent: https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/36379/installation---silentHow to Create a Deployment Image: https://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/37164/how-to-create-a-deployment-image
Regards,Anu
So what is the answer Anu?
Hi Larry,
I use SCCM too, and this is working well for me. It silently installs the connect client first with no pop up screens, then MicroStation with no pop-up screens. The user won't see the login or welcome pop-up screens until first launch. Note: my version of MS is 10.10.00.23.
Set the Connection Client as a dependency for MicroStation (so that it runs first). Use this command to install it: blg6410001022en.exe PostInstallLaunchApplication=1 /q
Use this command to install MicroStation: ms10100023en_updt10.exe /passive /quiet /norestart
What I haven't figured out yet is the command line switch to install Descartes along with MicroStation. I can install it standalone, but would rather bundle it.
