For one client I have to move all elements in references (i.e. topography is in one reference, telecommunications in another) to one level (i.e. topography should be on "level 1", telecom on "level 6") and then merge all references in one file. Now each of these elements use bylevel symbology (style, weight, color). I know how to remove the bylevel symbology for single levels (key-in: level element bylevel unset color + level name). I also know how to remove it from levels that are named level 1 to level x by just adding level*. I just don't know how to select ALL levels with different names at once. Anyone up for a key-in solution?
Is there a reason you can't just select everything with CHOOSE ALL?
MaryB
You might think this is an unusual method, but using the remap option under Save As might be a simple method to perform this operation.
https://communities.bentley.com/products/microstation/w/microstation__wiki/15002/remap-element-attributes-to-remove-bylevel-status
"level element bylevel unset color choose all" doesn't work... I'd need a wildcard to choose all levels and simply putting an asterisk at the end doesn't work. I need at least the first character plus an asterisk.
Thanks for your answer. This would probably do the job but involves a lot of work and you have to take care to catch all used colors and line styles.
However, I found this gem in the first reply to your linked article: https://communities.bentley.com/products/microstation/m/microstation_gallery/270663 which just does what I needed. Thanks Oto (and Andrew, of course)!
Hi
Does this VBA also work for Microstation Connect?
Helge
