How to force associate template without using customized tasks? Is there a similar tool like "synchbylevel"(MS_LEVEL_SYNCH_BYLEVEL) but for attaching templates? Or at least key-in to set it always active?
The Keyin if I understand correctly is
lock templateassociation on; xxx\yyy
Where xxx is the Template Group and yyy is the Template
See also
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/591/keyin-to-lock-the-active-element-template
https://communities.bentley.com/products/microstation/f/microstation-forum/113246/what-do-i-need-to-do-to-created-a-new-tool-bar-and-task-menu/346858#346858
Carl Myhill
Technical Support Engineer
Bentley Systems
Hi Oto,
in my opinion there is no such functionality available (btw what product / version we are talking about? ;-).
I am not sure how it should work, because "by level" can be always set to the same value regardless of MicroStation state (active level, tool etc.). But a template is associated with a tool and often also element type.
Or your question is about to only set the template association switch on, regardless what template is active?
Jan
Product could be any v8i Microstation/Powerdraft. What I need is to force the "associate template" to be always on without option to switch it off or only allow it to switch off for one time.
Something that works like this:
Enhancement Request 112302 has been filed.
