As the title says. Parametric cells do not export to dwg.
WTF bentley - it would have been helpful to include this in the help.
After spending an age learning these tools, then developing cell libraries and then placing the content, creating drawings etc. I now find out that parametric cells DO NOT export to dwg. No placeholders, no warning, just omitted content.
Is there a method to enable exporting of these elements? If so where?
very useful feature parametric cells, however, if they don't export, what is the point, this makes them unusable?????????????????????????
Maria,
I have uploaded the cell library and a sample dgn file containing some placed cells.
When saving to dwg, it produces 2 files. one named as per the dgn file, and another with the same name and the drawing model appended which contains the (successfully) exported geometry
neither contain the parametric cells.
thanks marco, appreciated
I don't think there is a straight out key-in for that operation but let us check if there is a way to automate it.
thanks Marco,
normally I would use SelectBy, however this does not include the parametric cell option.
Yeah, I got them. I will have a look at them and contact you again via SR.
Maria
